Why do induction steam boilers not exist?
Waher
Waher Member Posts: 372
edited February 2024 in Strictly Steam
With induction cooktops becoming more common, I wonder why the same technology hasn't matriculated into boilers and water heaters compared to heat pumps.
  • espire
    espire Member Posts: 23
    Induction is uniquely beneficial to stovetop cooking, where with traditional gas/electric burners, a majority of the heat would flow around the sides of the pot and be wasted. So while electricity is generally more expensive than gas per BTU, with induction burners you are getting much more of the energ into your food.
    On the other hand, boilers and water heaters are fairly efficient in terms of getting most of the energy into the water. Comparing the design of a pot to the design of a boiler, you will see many more opportunities for the heat to contact water in the latter, instead of just flowing around the edge. As a result of this, the increased cost of electricity per BTU at 100% efficiency will be higher than gas at, say, 80% efficiency.
    WaherWMno57ChicagoCooperator
    EdTheHeaterMan Member Posts: 12,127
    IN-DUCT-SHOWN
    I just broke down the word phonetically and I still cant see how the heat IN a DUCT has SHOWN any benefits over heat in a PIPE. Maybe I am looking at it the wrong way. but I like Steam and Water heat, and even radiant floor heat better that heat from a heat pump coming out my DUCTwork.
    But that's just me!
    dabrakeman
  • SlamDunk
    SlamDunk Member Posts: 1,803
    Jamie Hall Member Posts: 27,319
    SlamDunk said:
    Probably. But why? Ah yes. Looks good. You can't beat the conversion efficiency of an immersion direct resistance water heater.
  • SlamDunk
    Why? I dont know. Speed?
  • ratio
    ratio Member Posts: 4,229
    I've seen a place with induction heaters. They fuse quartz into blanks for manufacturing. They're on metered primaries.
    There are some things for which induction heaters are preferred. There are some things for which they are the only realistic heat source. There are some things, however, for which they are overkill -- and heating water in a tank or boiler is one of those (this is NOT the same as boiling a pot on the stove. There they are more efficient). So... for your very hot water or low pressure steam -- go immersion resistance heaters. For lower temperature hot water air to water heat pumps, or ground source, are much more efficient. For high pressure steam, so far at least you are better off with combustion or nuclear sources.
    ChicagoCooperator
