Cold weather heat pump COP
JOutterbridge
JOutterbridge Member Posts: 21
Crazy question here from a commercial tech. I work with Water Furnace and McQuay water source heat pumps all the time and they are very efficient. Recently I've been looking for a non inverter style heat pump for a Northeast residential home. Has anyone ever installed the Ruud/Rheem classic RPZ style units? Technical submittal shows a COP of around 3.9 at 47 degrees. And 3.0 at 17 degrees. Is this really possible with air to air? Feedback is appreciated, thanks. My apologies if model numbers are not allowed:(
Jon O.
    pecmsg Member Posts: 7,281
    If everything is done according to the book...............Maybe!
    Those #'s are ideal set up, like MPG you milage may vary.
  • Zman
    Zman Member Posts: 7,614
    edited December 2023
    Those numbers do seem high. Could you post the document? I am curious.
    Albert Einstein
  • GGross
    GGross Member Posts: 1,969
    Why non-inverter? Depending on the model and combination of heads LG red inverter units are capable of COP over 3 at -13f
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,243
    Those pretty typical COP ratings! A non-cold climate heat pump will lose capacity at 17F, but will be efficient.
