Help! Can I use a single water heater for two purposes?
AndrewHern
AndrewHern Member Posts: 8
Hi everyone, I’m new to the board. Can I use a single tank water heater for both purposes of heating my home and hot water? Is it legal? Is it safe? I live in northern NJ.
Thank you,
Andrew
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,182
    Hi and yes it can be done as long as you keep the potable water separate from the heating water by using a heat exchanger. Also, if the heating load taxes the water heater too much, it can greatly shorten the heater's life, as they aren't made to fire continuously.
    Yours, Larry
    AndrewHern
    hot_rod Member Posts: 28,039
    As per the 2021 IPC you can use a listed tank to do combined systems. Apollo and a few others are listed.
    Most plumbers shy away from mixing potable and heating water. Health and liability reasons.
    There are some aftermarket plate HX modules for separating.
    At some point a separate stand alone heater may be less $$.
    There are some tank type water heaters listed for hydronic applications, stand alone.
    The CombiCors are an option, special order and them price is getting close to a combi boiler.
    AndrewHernJohnNY
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,714
    I have a picture of a nice Combi-Cor I did with ALOT OF radiant connected to it.  It was a 50 gallon Model and heated 1/2 the house...Very happy w those Brad White Combis Mad Dog  🐕
  • JohnNY
    JohnNY Member Posts: 3,408
    Legal in NJ, not in NYC.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • jumper
    jumper Member Posts: 2,602
    In the seventies Apollo & others advertised circulating DHW through air handler for heating. Tank heater was more efficient than furnaces or duct heaters in those days. For low heating delivery and high DHW demand like ski chalet idea wasn't as dumb as it sounds. Plus coil could be used for wimpy A/C.
  • Jon_blaney
    Jon_blaney Member Posts: 340
    I use a 32 gal oil fired Bock water heater for hydro-air and heat half of my house. System has been in place for 20 years, no problem. I do not have a heat exchanger. This is a high fire tank, 104000 btus, I think.
  • Mad Dog_2
    Yes, legal in every municipality in NYS.  Otherwise.  Mad Dog
    ethicalpaul Member Posts: 8,970
    Everything's legal in NJ!
    Mad Dog_2
  • Mad Dog_2
    Gotta Love Joisey...."You from Joisey???
    I'M from Joiesey!!!"  Second best place to live & work.  NY, the cool Older brother is the Best!   Ha ha   Mad Dog
