Burned wire insulation on Goodman flame sensor wire
I replaced the wire but there are no signs of a torch or other heat source. There are other wires that are touching the burner box below that are not marked like this one and the wire seemed to have been up out of the way the entire time from what can be seen.0
No signs of a torch? How about that burned wire...that seems like a sign
See my sight glass boiler videos: https://bit.ly/3sZW1el2 -
I may be seeing the start of the same thing. When my ignitor starts, the flame sensor wire emits a small continuous blue spark where it touches the frame supporting the gas line. There is a small amount of soot there. Furnace is only starting some of the time. I wonder if it's a ground issue. I cannot find anything online about it.0
That wire got heated from something. lots of discolored insulation0
Hello @BigPerm,
Sounds like in your case the insulation is probably age related dilapidated and the high voltage is arcing to the nearest ground. The one pictured looks like a torch or other flame got to it, since it is out in the open and not near metal to arc to. In either case the wire should be replaced.BigPerm said:I may be seeing the start of the same thing. When my ignitor starts, the flame sensor wire emits a small continuous blue spark where it touches the frame supporting the gas line. There is a small amount of soot there. Furnace is only starting some of the time. I wonder if it's a ground issue. I cannot find anything online about it.
One Pipe System0 -
Different problem, someone posted on a thread, with not the same problem.EBEBRATT-Ed said:That wire got heated from something. lots of discolored insulation
One was the melted wire, 2nd is about a spark jumping to ground.0 -
You should start your own thread.BigPerm said:I may be seeing the start of the same thing. When my ignitor starts, the flame sensor wire emits a small continuous blue spark where it touches the frame supporting the gas line. There is a small amount of soot there. Furnace is only starting some of the time. I wonder if it's a ground issue. I cannot find anything online about it.
