Custom hook to pick up steam radiator using electric hoist
One radiator is posing a bit of a problem. The side fins are too tight for the rod to get into. That means I have to hook over the top section. But the hook will make contact with the threaded rod that holds all the sections together. I tried pushing a straight 5/16 rod through that gap and it won't fit. So no chance of getting a hook through. Will the hook contacting the threaded rod with the weight of the radiator damage the rod?
Here are some pics to explain my situation a bit better:
I'm using two hooks.Jamie Hall said:Not ideal, but if you don't jerk on it it should work. Are you using just one hook? Can you use two, set about a quarter of the way in from each end? That would be better.
1/4" wire rope with crimped loop? I was never sure how much weight a crimped wire rope can handle.pecmsg said:1/4” wire rope will handle it
Thanks guys.0 -
I admire your guile and Mc gyver rigging, just be careful please. We've been finding some threaded rod that looks normal but is a cheap knock off and have snapped instead of bending under stress. Also, your come-along or chain fall is only as strong as the beam or member it is hitched to. Are u happy with the job the lye bath is doing?
What do you rinse it off with? I prefer the hand truck to sandblaster/paint shop and reinstall. Much less mess and safer. My opinion. Either way good luck. Mad Dog1 -
Here is the Kindorf Catalog.
Page 100 has the load specifications.
https://search.abb.com/library/Download.aspx?DocumentID=9AKK107046A5710&LanguageCode=en&DocumentPartId=US&Action=Launch1 -
Soft ties for motorcycles. A thin webbing with loopsBob "hot rod" Rohr
Living the hydronic dream0 -
This is an adjustable hook device that I made to pick up radiators with a hoist. It works real well and is easily adjusted.1
The lye bath works fairly well. It takes about 48 hours for each radiator (one flip halfway thru). After the lye bath I move it along the "assembly line" to a washing bin. I spray it down with vinegar to neutralize the lye and then hose it off. Some spots require a little wire brushing.Mad Dog_2 said:I admire your guile and Mc gyver rigging, just be careful please. We've been finding some threaded rod that looks normal but is a cheap knock off and have snapped instead of bending under stress. Also, your come-along or chain fall is only as strong as the beam or member it is hitched to. Are u happy with the job the lye bath is doing?
The lye doesn't move the rust on the radiators. Some are more rusty than others. I have used wire attachments on my drill to remove the rust in the past. I might try electrolysis to remove the rust on the radiators. I've done this with various old tools, Jeep parts, etc.
My setup is a 10' unistrut, 2 unistrut trollies, and 3 channel trolley supports. The supports are hung with 1/2" thread rod and rod hanger plates. The plates are screwed into 3 different joists.
I don't know much about sandblasting. Looks like s/b would take off the paint and rust and the process would be over fairly quickly. Do you just blast outside in the backyard?1 -
@branimal, Do you have any idea how much weight you've been able to lift with your set-up?
I have a need for a small hoist set-up, and an arrangement like yours might fit my needs.
Thanks.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
I have done sandblasting in my yard. I needed a bigger compressor than I had, I did a lot of waiting for pressure to build back up.
I would just get some small chain and an eye that screws on the chain and thread it through the space.0 -
Atleast on Long Island 🏝 Sandblasting is cheap...The come our SOOOOOO perfect...like brand new C I. (No rust..all raised detail. Then they powder coat them any color u want. They do my rads very reasonably. IM for more details. Most Industrial parks are going to have a Sandblasting/paint shop...maybe several shop around. Hardest part is getting them down/up the stairs and back. Moving companies will do this. I know lye is nasty and will burn a hole through your hand...ain't worth it to me. Mad 🐕 Dog1
So the largest rad I picked up is 25H x 21 W x 8" D. It is made by National Art Radiator. If you can estimate the weight, please let me know how you calculated it. Pics attached.Pumpguy said:@branimal, Do you have any idea how much weight you've been able to lift with your set-up?
Thanks.
I am going to put a pulley on the hoist, which doubles the lifting capacity for the largest radiator I have.
1 -
Look up the load rating in the manual I posted.branimal said:I admire your guile and Mc gyver rigging, just be careful please. We've been finding some threaded rod that looks normal but is a cheap knock off and have snapped instead of bending under stress. Also, your come-along or chain fall is only as strong as the beam or member it is hitched to. Are u happy with the job the lye bath is doing?
The lye bath works fairly well. It takes about 48 hours for each radiator (one flip halfway thru). After the lye bath I move it along the "assembly line" to a washing bin. I spray it down with vinegar to neutralize the lye and then hose it off. Some spots require a little wire brushing. The lye doesn't move the rust on the radiators. Some are more rusty than others. I have used wire attachments on my drill to remove the rust in the past. I might try electrolysis to remove the rust on the radiators. I've done this with various old tools, Jeep parts, etc. My setup is a 10' unistrut, 2 unistrut trollies, and 3 channel trolley supports. The supports are hung with 1/2" thread rod and rod hanger plates. The plates are screwed into 3 different joists. I don't know much about sandblasting. Looks like s/b would take off the paint and rust and the process would be over fairly quickly. Do you just blast outside in the backyard?
What do you rinse it off with? I prefer the hand truck to sandblaster/paint shop and reinstall. Much less mess and safer. My opinion. Either way good luck. Mad DogI’d run 3/8” rods every joice to be safe.1 -
Pumpguy…I used to use a hoist like that until the switch burned out. I don’t remember it’s capacity but I’d say 800 pounds is ok so most radiators would be fine. They’re economical, 110V, and fast. I rigged one to a gantry crane and trolley When the switch burned out I was able to reasonably find an old Budgit 1T chain hoist to replace it. That hoist isn’t nearly as handy. If I were to do it again I’d just buy a new replacement of the featured hoist. As many have pointed out capacity is really about what the hoist is hanging from.
I absolutely recommend sand blasting over anything else…if you’re lucky enough to have a good place to do it.0
- 128 Chimneys & Flues
