Flame color on Williams gas wall heater / Flame burst
iOne
Member Posts: 4
in Gas Heating
What could be causing this? This is from a 24 unit apartment, and this one heater has a more yellow flame:
And a bit of a flame burst when cold:
https://photos.app.goo.gl/aTYzAYiDF1u66Yvr7
Dust or dirt in the manifold or feed to that burner.Br. Jamie, osb
Got the low level CO detector, but will be referring out to a specialist beyond that.pecmsg said:Get a combustion analyzer and the training to use it. Low-Level CO detector.
A comparable unit in the same building, same age of Williams Monterey wall furnace, burns like this:
https://photos.app.goo.gl/j4Sn33SD1gdaA67H9
The manual says straight up there's no adjustment for the combustion air mixture. Is that really true? Is it possible a flue issue could cause the flame color?0 -
An ultrasound humidifier will cause the flames to look odd. Because it mechanically atomizers the water, any minerals that are present end up in the air as well.0
