Joist Track PEX Hole Size & Position
Marvin007
Marvin007 Member Posts: 52
edited December 2022 in Radiant Heating
Will I get snapping sounds when the PEX expands if the PEX is touching the back of the hole when it goes through the joist to the next chamber?
  • jhewings
    jhewings Member Posts: 139
    I used this product to keep the pex away from the wood. It can be wrapped around the pex.
    https://www.supplyhouse.com/Uponor-Wirsbo-A7250500-1-2-PEX-Suspension-Tube-Clamp-Bag-of-100
    Marvin007
    pecmsg Member Posts: 7,273
    On the initial startup its possible but the water flow should be constant so no more movement.
    Marvin007
    ethicalpaul Member Posts: 8,929
    No, I don’t think so. mine is exactly the same as your picture.
    Marvin007
    hot_rod Member Posts: 27,815
    some foam pipe insulation is an inexpensive way to make an isolator. No harm in doing it.
    Marvin007
  • TAG
    TAG Member Posts: 806
    The only time I ever hear any expansion noise is on initial start .... very minor if at all
  • Dave H_2
    Dave H_2 Member Posts: 626
    I would use the clamps the jhewings suggested above. The one photo that shows the pipe in the middle of the hole looks great right now and looks like it would never make noise. However once that pipe starts to heat up, it will grow linearly. The formula is for every 10 degree rise it temp, it will grow 1.1" per one hundred feet of pipe.
    The other thing I would do is to make sure the water temperature delivery system is weather compensation based. Modulate the water temp as it warms up/cools down outside makes that expansion of the pipe minimal.
    Dave H.
    Dave Holdorf
    Taco, Inc
    Marvin007Rich_49
  • Zman
    Zman Member Posts: 7,614
    Albert Einstein
    Marvin007
  • Marvin007
    Do you mean foam pipe insulation like this where the pipe touches the crossing pipe. I only have a short piece of foam at the moment but I could use longer pieces.
    Sure, anywhere tube can run is a good use of pipe insulation
    Typically 1-3/8” holes are drilled. That allows plastic isolators or thin walled pipe insulation to be used
    Interesting use of a Studor air admittance device 🤭
  • Marvin007
    hot_rod said:
    Sure, anywhere tube can run is a good use of pipe insulation Typically 1-3/8” holes are drilled. That allows plastic isolators or thin walled pipe insulation to be used Interesting use of a Studor air admittance device
    I drilled 1-1/4” holes. Hopefully this is ok.
    The Studor air admittance device is being used as an added percaution/assistance to the vent that leads to the roof. The drain vent stretch is very long but is slopped correctly.
    1-3/8" is typically the plumbers go to size drill, for some reason. Many of the insulators require that size, especially the drive in type.
    When we worked with TJI type joists, an 1-1/2" hole could be drilled anywhere in the web.
    So the 1-3/8" was a safe drill to use in those.
    As long as the tube is free to move, not tight against the tube so the tube could expand, you should be fine.
    Marvin007
