How to reduce heat emanation from hot water tank
I just rented a house and didn’t look inside the fitted cupboards in my bedroom ahead of moving in. I have now found it has a hot water tank in it and I’m really miffed it’s probably going to be unbearable in there during the warmer summer months. Is there anything I can do to keep the heat in the cupboard? Will putting a jacket on it help? Is there anything I can line the cupboard with? TIA
    Jamie Hall Member Posts: 27,580
    There are insulating jackets made just for the purpose. Lowe's has them.
    pecmsg Member Posts: 7,281
    Gas or Electric?
  • DianaB1111
    DianaB1111 Member Posts: 2
    pecmsg said:
    Gas or Electric?
    Gas
  • Zman
    Zman Member Posts: 7,614
    edited May 2022
    You might want to post a few pictures of this one. There are quite a few reasons that installing a gas-fired appliance inside a cabinet can be very unsafe, especially in a bedroom. Think CO poisoning and/or fire. :(
    Albert Einstein
    pecmsgkcopp
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    Hi, As @Jamie Hall said, put a blanket on the tank itself. Get one that's thick! Not one of the common thin ones... or double up on them. R-11 would be nice. Also, insulate both hot and cold lines at least five feet from the heater if possible. Insulate the relief valve too. Use foam insulation at least 3/4" thick for this.
    Although I like to keep tanks around 130F for bacteria concerns, you may want to turn it down to 120F, so there is less heat escaping... and less scald risk.
    Yours, Larry
    pecmsg said:
    Gas or Electric?
    Gas
    Please say there’s a louvered door?
