Need Opinions: Lazy or Incompetent Plumber??
FredoSP
FredoSP Member Posts: 124
edited March 2022 in Plumbing
Hello Forum,
I recently had a leak behind one of my walls and the contractor replaced the faulty pex clamps with newer ones and brand new pex. The picture below is what he did in my bathroom. While it may be correct and to code (I hope), I don't understand how a professional could think this looks good? Couldn't he have used a brass nipple or something else so I don't have to see the blue pex past the escutcheon plate? Unfortunately I was not home for the repair and would have mentioned it to him if I was.
What are your thoughts?
Long Island, NY
  • SlamDunk
    SlamDunk Member Posts: 1,818
    Looks good to me.
  • Intplm.
    Intplm. Member Posts: 3,069
    Not a lot of blue is showing there but I sure do understand your concern.
    There are chrome sleeves that can be installed over the blue so you don't see any blue.
    Maybe have them cut the valve in tighter to the wall so the pipe cant be seen?
    mattmia2rick in Alaska
  • PC7060
    PC7060 Member Posts: 1,825
    edited March 2022
    Another tone deaf / color blind plumber. We are all used to exposed copper, pvcs or even white pex but blue pex (or red) is over the top.
    Supply house has cosmetic sleeves for that purpose.
    I’d just paint it white and move on.
    Intplm.
    hot_rod Member Posts: 27,702
    it’s fine. The stop could have been moved right to the escution, no exposed pex, an easy fix.
    Supposed to be plastic escutcheon on Pex, not metal.
    EdTheHeaterMan Member Posts: 12,442
    edited March 2022
    DJD775
  • MikeL_2
    MikeL_2 Member Posts: 545
    edited March 2022
       I'm not a fan of that plastic nut on the supply tube. I've seen that nut fracture a dozen times or more just in my small service world.
        Water logged water tanks, high water pressure ( especially at night in public water supply systems ), or other unforseen circumstances can contribute to water hammer when the ballcock shuts off.
           We use braided supply connectors with a brass top nut, and we use a brass top nut with chrome plated supply tubes.......
  • Sal Santamaura
    Sal Santamaura Member Posts: 546
    edited March 2022
    Six years ago we had the entire house repiped with Uponor PEX. All the shutoffs, toilets and sinks, look that way, hot (red showing) and cold. Last year our next door neighbor had the same thing done, and it's still the same.
    My only caution is to hold the shutoff with one's left hand while turning the handle with one's right hand. A small precaution to ensure not twisting the shutoff right off the PEX, since our risers are flexible, not rigid. Just in case. :)
  • MikeL_2
    edited March 2022
        I agree with Mattmia - we use Uponor pex and their pex x 3/8" 90° female adapters for most fixture valve stub outs. At trim time, we install 3/8" brass or CP nipples as needed with a CP bell escutcheon & 3/8 ips angle stop.
        We did it the same way in the 70's & 80's;  the female adapters in the wall cavity were copper.
    danielcote
  • ChrisJ
    ChrisJ Member Posts: 17,481
    edited March 2022
    Six years ago we had the entire house repiped with Uponor PEX. All the shutoffs, toilets and sinks, look like that way, hot (red showing) and cold. Last year our next door neighbor had the same thing done, and it's still the same.
    Uponor makes chrome sleeves and covers to cover the PEX.
    Uponor also sells copper stubouts as well. Tia is the route I went in my own house so all of the stops are supported.
    My parents house is done all in Uponor pex as well from 2006 and all of the toilets have chrome connections.
    Yes having the PEX stick out is a way to do it but I wouldn't really say it's great. I'd at least want a chrome sleeve and cover.
    The good news is it's just cosmetic so it really doesn't matter.
  • SlamDunk
    More time, more money, but it looks better.
    I wonder if op had the wall open?
    kcopp
  • ChrisJ
    Is that a galv nipple?
    Regardless, there's more spots to leak there.
    pecmsg Member Posts: 7,186
    X-2
  • ChrisJ
    The last thing I want are threaded connections in the wall.
    This is what I used as well as the straight version.
    danielcote
  • DJD775
    DJD775 Member Posts: 259
    Threaded connections in walls are pretty common in shower heads. Your method has one less failure point in the wall but if properly installed it shouldn't be an issue.
  • ChrisJ
    That's true.
    The above example only has one less failure point and that's not much unless it's the one that leaks.   If you run the PEX straight out into the stop there's now no joints in the wall there.
     I could have worded my last response better.
    There's a lot of worse things to have in a wall than a threaded joint.
  • DJD775
    In all fairness my shower head example is not exactly equivalent as there typically not as much pressure in that joint unless you have a shutoff valve on the shower head.
  • ChrisJ
    True, and it's not always pressurized.
    But I think it's still a valid point.
  • MikeL_2
    edited March 2022
       Any piping material has it's fatal flaws. Copper or brass water piping doesn't hold up as well as pex when the water supply has low PH.
        I've seen pex gnawed through by thirsty critters; copper & brass not so much. And pex tubing usually survives extreme cold better than copper or brass.
    Larry WeingartenShane_2Alan (California Radiant) Forbesdelcrossv
