Updating old convector radiators in condo unit in Silver Spring
My recently purchased but old condo unit has three convector radiators I want to update. How doable is that? I have one technician tell me he's hesitant to do it because he can't guarantee that the hot water would flow properly through the numerous passages in modern set ups. How true is that? I'm thinking of replacing with a modern single panel convector or a baseboard unit, even. Does that make it more feasible? Check out the photos below of one of my current units. Recommendations on anyone who might be able to help me update the convectors in my condo in Silver Spring MD? Thank you!
    Jamie Hall Member Posts: 27,574
    It's certainly doable. It may change flow balance between radiators, but that's minor and can be adjusted for. The real trick is to get new radiators or baseboard or whatever with approximately the same heat output as what you have -- assuming that the heating is OK, but it's an aesthetic thing you are interested in.
    paolomartin
    Steamhead Member Posts: 18,697
    edited September 2021
    Consulting
    paolomartinIronman
  • paolomartin
    paolomartin Member Posts: 3
    @Jamie Hall I agree, it's mostly an aesthetic issue as my condo unit is largely updated throughout, except these radiators. Functionally, I don't know how well these radiators work as I've only had the place since July.
    @Steamhead thanks for the referral. @Dan Foley do you think you can help me out before they turn on the boilers in November?
    You can send @Dan Foley a personal message. Just click on the name in sort of red there, and it will be e-mailed to him. Or click on the link @Steamhead gave you and that has his 'phone number.
    paolomartin
  • paolomartin
    Thanks @Jamie Hall for helping me orient how to get a hold of @Dan Foley. Hope to get a hold of him this week.
  • Natalie
    Natalie Member Posts: 2
    Is it possible to replace the 1940’s Convection Metal Radiator cover with something more visually appealing, like wood? If so, any photos and/or tips would be appreciated!
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    Custom wood covers are available, but are often built by cabinet makers. Dan Foley would know of access.
  • Natalie
    Thank you!
