Water softener flooded
ChrisJ
ChrisJ Member Posts: 17,443
So...
If a water softener was in a flood but electrically still works... Is it safe to clean out and load new salt in and fire it up good to go?
Or would it be contaminated on the potable side?
    Jamie Hall Member Posts: 27,434
    It's not a matter of contamination. No appliance which has been flooded should be used again.
  • ChrisJ
    So you don't know?
    No, it wouldn't be contaminated inside. There is no potable side as such. Those things are really just a big tank with salt and, in the fancier ones an electrical valve to control the backwash.
    If the electrics didn't go underwater, @ChrisJ , you should be able to use it.
    Zmanmattmia2ChrisJJUGHNE
