Maximum temp of outside of pipe in steam system?
bostondan
bostondan Member Posts: 19
What is the maximum temperature of the outside part of a pipe in an old steam radiator system? I need to place something relatively close to one of the steam pipes that is exposed from floor to ceiling, but don't want the item to melt.
Operating temperature of the material is up to 110 c. Will that be sufficient? If not I will have to find a different solution.
Thanks!
    pecmsg Member Posts: 7,285
    What pressure?
  • nicholas bonham-carter
    Is this pipe supplying heat to the surrounding space, or can it be insulated?—NBC
  • ChrisJ
    ChrisJ Member Posts: 17,520
    edited May 2021
    If this is a home heating system or similar the pipe should run around 212-215 (100-102C)
    I have a home theater speaker sitting about an inch from one which is enough of an air gap to not cause harm, at least not for a long time. See if you can hold your hand by it at the same distance for a long time, you'll see what the item will feel etc.
    Another pipe is fairly close to the condenser on an antique refrigerator so I'm wrapping the pipe with PVC covered melamine foam pipe insulation as I don't feel I need that extra heat being transferred into the condenser.
    Material good to 110C should be fine right up against the pipe honestly.
  • bostondan
    Great, that is very helpful. The pipe goes into the wall at an unusual angle and when we moved in there was no pipe flange, just a big hole in the wall around the pipe. No pipe flange I have found would fit around this because the bottom part where it goes into the wall is too close to the wall and nothing fits.
    I was able to design and print a nifty pipe flange and print it with my 3D printer, but the PETG filament is only supposed to be used up to 110C, which is why I originally asked this question. The flange I printed was made to be narrower on the bottom part so that it would fit.
    I'm glad to know that the temperature range seems to be acceptable for this material, even if it is at the upper limit.
    Here is a photo of it currently. This was just the draft print, but I plan to print it better quality and paint it.
    ChrisJCanucker
