What part do I need? Picture included.
Redhawk24
Redhawk24 Member Posts: 28
I'm 1" short installing the hot water line for a new faucet. What's the simplest way to fix this? Is there a male to female extension?
    pecmsg Member Posts: 7,186
    Longer connector
  • Redhawk24
    Connector is pre installed with the faucet I bought. What’s another solution?
  • Redhawk24
    Jamie Hall Member Posts: 27,513
    Your best bet is going to be to install a longer piece between the T and the shutoff valve.
    Larry Weingarten
    HVACNUT Member Posts: 7,507
    edited April 2021
    Get a 12 inch Speedy and loop it. Hold it with a couple zip ties.
    Is the bull of the Tee for a dishwasher? Where's the valve for that?
  • Redhawk24
    What’s a speedy? The right side is the cold and has a tee going to a RO unit.
    Alan (California Radiant) Forbes Member Posts: 4,767
    edited April 2021
    I use a 3/8" nut x 3/8" compression connector. I remove the nut and ferrule off the compression side and it screws into the end of the supply line on your faucet. The nut end screws into the valve.
    Do not get a nut x nut supply line. It only has female threads.
    mattmia2 Member Posts: 17,204
    you can get 3/8" supply lines with a compression fitting soldered on one end, that would do it.
  • STEVEusaPA
    edited April 2021
    Lol. You think they’re going to solder? Or know how to, based on what they posted. They won’t even go buy a longer connector.
    hot_rod Member Posts: 27,702
    edited April 2021
    A compression tee and cap, or additional Female by male compression straight stop. Both are available at box stores..
  • Redhawk24
    No need to be a jerk. I would buy a longer connector but can’t. The faucet we bought a new connector cannot be replaced. Be helpful not rude.
    STEVEusaPA
  • Redhawk24
    Thanks! The tee would work. Is there a way to get similar without it being a tee, just straight?
    Well, yes. I sort of assumed the OP had already thought of using a simple mail to female connector -- either flexy hose or what have you... and rejected that option. Silly me.
  • Redhawk24
    That’s exactly what I’m looking for but cannot find it.  What would that be called so I can search for it online say via Home Depot? Thanks.
  • Redhawk24
    I use a 3/8" nut x 3/8" compression connector. I remove the nut and ferrule off the compression side and it screws into the end of the supply line on your faucet. The nut end screws into the valve. Do not get a nut x nut supply line. It only has female threads.
    The top picture is exactly what I am looking for. How do I find that online?
    you can buy it already made up for faucets that have 3/8" supply stubs
  • Redhawk24
    Thanks. What would it be called so I can search for the part online?
  • Redhawk24
    mattmia2 said:
    Thanks for the help. That doesn’t look like male to female though no? That’s what I’m having difficulty finding.
    The compression ferrule and nut (either the one that came with the stop valve or the one from the riser) connects the copper tube end of the riser to the supply stop and the nut and gasket deal on the faucet supply hose connects to the compression fitting on the riser.
    Ah... take the nut and ferrule off one end and connect that end to the faucet connector... connect the other end, with it's nut and ferrule still on, to the valve...
  • rick in Alaska
    rick in Alaska Member Posts: 1,524
    You can just get a regular supply line and a 3/8 compression by 1/2" male adapter. Screw the supply line onto the valve, and use the adapter between this line and the one from the faucet.
    Rick
    edited April 2021
    This is the one I showed you. A plumbing supply company or Ace Hardware store should have them in stock.
    https://www.menards.com/main/plumbing/plumbing-installation-repair/supply-lines/proline-3-8-compression-x-3-8-female-compression-braided-stainless-steel-faucet-supply-line/496-073/p-1444425450696.htm
    If they only have a nut x nut supply connector (the second picture from my original post), purchase a 3/8" compression coupling and remove the nuts and ferrules to change one end from female to male.
    There are a hundred ways to do this if you get a piece of 3/8" copper tubing and venture in to the fittings section.
  • Doggle12
    Doggle12 Member Posts: 1
    Next time its called a Delta tube.
