Cast iron radiators of various sizes and shapes make an offer Danbury CT
Hello,
I have various sized cast iron hot water radiators available. I recently switched to forced air (no need to comment) and we no longer have a need for cast iron radiators. I was going to cut them up and take them to the scrap yard but these are coming out of an 1867 home and I am sure they might fit someone else's needs. Let me know if you are interested and I will supply pictures (no need to stuff the cloud full of data if no one is interested).
Thanks,
Ron
Danbury, CT
  • LS123
    LS123 Member Posts: 476
    hello @hutchinsron , could you send me some pictures of the rads? I want to take a look at them, and make sure I can attach them to my existing steam system. thanks you!
    Thank you!
    @LS123
  • hutchinsron
    hutchinsron Member Posts: 28
    This is a hot water system with water in on one side and water out on another.
    Jamie Hall Member Posts: 27,582
    @LS123 and @hutchinsron -- in which case they may well work, or work with one modification (;shifting the inlet from the bottom to the top, which is a bore but usually doable (I forget, @LS123 , whether you system is one pipe or two? If it's one, you wouldn't even have to do that -- plug the outlet and put in a vent) When you get pictures, if you don't post them on the wall, can you forward them to me and I will comment on them in that regard.
    For reference, it's going the other way -- from steam to hot water -- that causes headaches.
    LS123
  • hutchinsron
    LS123kcopp
  • JUGHNE
    JUGHNE Member Posts: 11,603
    Maybe if he knows if inlet was on top or bottom would answer what he needs to know.
    Those can be made to work, @LS123 .
    LS123
  • hutchinsron
    These are about half the number I have but gives you the idea of what they are. All are fed by 1/2” copper. Total of 16 radiators.
  • LS123
    @hutchinsron ... it appears to those type of rads cant be used for steam.... I thank you and @Jamie Hall
    Thank you!
    @LS123
    Steamhead Member Posts: 18,707
    @LS123 and @hutchinsron , those look like American "Corto" radiators. Whatever the brand, they were made to be used with either steam or hot-water. You just have to change the pipe connections and vent tappings.
    And yes, @hutchinsron , I'm going to say it- abandoning that system is not a good idea. That house will never be as comfortable with forced-air.
    Consulting
    LS123Erin Holohan HaskellethicalpaulRomanGK_26986764589
  • LS123
    @Jamie Hall @hutchinsron @Steamhead ... thanks for clarifying the post... I misunderstood that the rads would not work with steam... @hutchinsron will send you a note tomorrow. Thank you all
    Thank you!
    @LS123
  • hutchinsron
    Steamhead said:
    @LS123 and @hutchinsron , those look like American "Corto" radiators. Whatever the brand, they were made to be used with either steam or hot-water. You just have to change the pipe connections and vent tappings. And yes, @hutchinsron , I'm going to say it- abandoning that system is not a good idea. That house will never be as comfortable with forced-air.
    On the contrary we have been so much more comfortable with this set up. Before we had a cold kitchen and dining room and all on one zone (upstairs and downstairs) and now we have two zones and lower fuel bills (switched from oil to natural gas which was already in the house).
    Most had advised against this conversion on this forum but we have been pretty happy so far.
  • SteamCrazy
    SteamCrazy Member Posts: 103
    Hello, , Mr Hutchinson I maybe interested in the Radiator that hangs on wall. Do you still have it ?
  • hutchinsron
    Yes still on the wall.
  • psb75
    psb75 Member Posts: 1,154
    Wow, that is a cast-iron "goldmine."
    (Esp. for a chiropractor.)
    Erin Holohan Haskellkcopp
    Which means, you had the wrong people working on it.
    Consulting
    pecmsgethicalpaul
    pecmsg Member Posts: 7,281
    Too late now but I do love using the radiators for drying my winter clothes, gloves, boots.
  • hutchinsron
    That’s about all we are missing after disconnecting and moving to forced air. Cant replace that!
  • hutchinsron
    I have 16 in total. I have one that is spoken for (the one that is wall mounted in the picture above). These are free to a good home, as long as you provide the muscle and finesse to get them out of my house without damaging the house. Thanks all. I will begin disassembling these radiators in pieces in about 3-4 weeks.
    Thanks.
    kcopp
  • JakeCK
    JakeCK Member Posts: 1,502
    ohhh rrrmmm
    Darn CT is like 8 hours from me. I would already be driving for the two smallest ones pictured if weren't for the drive. They're comparable in size and style to my bedroom rads and several downstairs. If I ever finish my attic, basement, or add on to the back...
    Still I hate to see good pieces like this in the scrap pile. I must ponder on this.
  • hutchinsron
    Here are the radiators I have available and their sizes.
  • hutchinsron
    Tall
    Wide
    Long
  • psb75
    That is a 'crazy nice' stash of cast iron. DO NOT SCRAP it!
    Someone should 'snatch' it! Must be a good 'rigger' though.
    Assuming some are on upper floors. (emphasis: nice antique hardwood floors!)
    hutchinsron
  • hutchinsron
    I have one radiator left the 11x14.5x72" radiator is the only one that remains. It is behind a tub in an alcove and probable impossible to get out.
