One pipe radiator on a two pipe system
Our building of nine condominiums in an old 1896 Denver square is heated by two pipe steam. It has an old Dunham Return System (originally vapor) that was converted from coal to gas. Every radiator is two pipe with steam traps save one. There is one unit where the developer that did the condo conversion installed a radiator just like above: one supply (and return) pipe on the bottom of the radiator, pitch toward the valve, with an air vent half-way up the opposite side. It works without water hammer. We had debated whether to repipe it and decided against it due to cost. I now feel good about the decision.
1 -
I can't think of a reason why a "mixed" system like this would have any trouble…if steam with a little pressure is available at the supply pipe going to this radiator, it's fine.
But my question is: why is the vent hissing? Do you have main vents operating? Is the boiler oversized? Are the pressure controls set too high?
I'm surprised this works. Condensate from one pipe goes into supply?
Yes — just like condensate from the pipe itself. If it's just one radiator, unless it's huge, it's no big deal.
Due to the one pipe, it has to release air to fill with steam making a light breathy hiss and take in air to release condensate, the hiss should be stopping once the steam pressure rises enough in the radiator, if not then I would replace the vent valve if it has some age to it, internal seals might be worn
OK. Just for comparison, none of my vents can normally be heard (but the air escaping can be detected with a wet finger or careful close listening).
When people say "hissing" I think "hissing", not "light breathy hiss" so if you have the latter, all good.
There is nothing about venting in a 1 pipe radiator that allows the release of condensate. They are built so that the water will flow out regardless of pressure.
The air escape should stop not when steam pressure rises enough, but rather when steam gets to the vent and closes it. Or if your system is really properly sized and balanced, the call for heat will end before the radiator is completely full of steam.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
