Pipe Confusion
klal
klal Member Posts: 26
This is likely a simple question, but I'm confused nonetheless. I'm looking to repipe a section of a steam riser (1-1/4) from the radiator to the main. Sites like supplyhouse.com clearly label some (but not all) fittings as "Black Cast Iron Steam" for instance, but Home Depot and Lowes have "Black Iron", "Black Steel" and "Black Malleable Iron." I'm sure there is a difference, but I'm clearly not aware of it.
    Jamie Hall Member Posts: 27,218
    Not really much difference in material, perhaps, although malleable iron is not the same thing as cast at all. But... usually a significant difference in quality of the fitting, particularly the threads.
  • klal
    What should I steer clear of then, which is the best option? Or are you referring more to the manufacturer? Supplyhouse.com carries mostly Ward for their domestic fittings.
    Go with Supply House
  • klal
    I'll likely get the fittings from Supplyhouse.com and the longer run (10 ft) of pipe from Home Depot. The black steel piping from Home Depot is rated for natural gas and air supply lines and has a max PSI of 1200, that would work well enough then?
    pecmsg Member Posts: 7,020
    Are you threading this pipe? Might want to consider American made. Blackman, Ferguson. More $ much better quality when threading!
  • retiredguy
    retiredguy Member Posts: 1,086
    edited October 2020
    What ever you do do not buy the foreign made "crap", buy only the "made in the USA" brands. Most of the foreign stuff is garbage. I can tell you about the horror stories from using foreign fittings.
  • klal
    Two questions, first would this fitting work for steam (it does not say steam specifically anywhere). I am using it for the above referenced return to the main:
    https://www.supplyhouse.com/Ward-FBUN1-1-4-1-1-4-Black-Union
    And is there any real difference between the following reducers:
    https://www.supplyhouse.com/Ward-FBCO1-1-4X1-1-1-4-x-1-Black-Coupling
    and
    https://www.supplyhouse.com/Ward-FCIRE1-1-4x1-1-1-4-x-1-Black-Cast-Iron-Steam-Reducer-459000-p
    ethicalpaul Member Posts: 8,626
    Answer #1: Yes
    Answer #2: One is malleable iron and one is cast iron. I'd buy the cheaper (malleable) one.
    STEVEusaPA
