How to stop water when soldering pipe
Dairon421
Member Posts: 81
Hey guys so I am installing a water heater and saw a leak on the main line. I turned the water off to the whole system but I can't solder because water is still coming through. What are your techniques for this problem?
A trickle or a stream. The bread trick may work unless you have a stream and some pressure.
If it is copper or galvanized, a freeze cuff, pex can sometimes be pinched with a special vicegrip tool for that purpose.
Press tools are another way to add or replace a valve with some flow in the pipe.
I've also used compression fittings as well as the Sharkgrip, in a bind. You can buy ball valves with press, grip or compression fittings at the box stores.Bob "hot rod" Rohr
Living the hydronic dream0 -
If it's just water in the pipe and not a valve leaking by sometimes you can take a hanger or two off and let the pipe sag so the water will run out.
If your trying to patch a leak just cut the pipe get the water out and put a coupling in0 -
What has worked for me is to loosen the fitting on the water meter outlet and catch the water stream in a bucket or pan. Or if you're lucky have a floor drain close.
This will get the main pipe dry enough to solder on.
You should replace the main service valve also. You would need to shut off the curb stop outside for this.
I usually put a hose bid on the main right after the water meter. This is handy for any future work to drain back piping.4 -
Don’t attempt without shutting off the water, if you don’t have a curb key get one there under a 100 bucks imagine the damage if the supply line let go and you had to wait a hour plus to get someone to come shut it off cheapest insurance you can buy0
Sharkbites in a pinch. (Always keep a variety of those in the house! ).
Take a breather then try the bread thing or call a plumber with a propress or a freezer.0 -
I've used the bread trick many times with good success. Its suprising how many slices of bread you can stuff into a 3/4" copper pipe!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
That is good for draining water out of a low spot in a line if you don't have compressed air available as well.0
Vent the system from a high point faucet and find the lowest point to drain it like a low-level sink or outside faucet. Leave these on and allow time for the water to drain. Be sure that the valve to shut off the water is tightly closed. You can use bread stuffed into the pipe if very little water is trickling out.
You can also use a tool called a jet swet pictured here. Be sure to purchase the correct size.
1 -
Back in the day there was a tool that allowed you to stop water flow. I used this tool to replace main valves up to 11/4". You inserted the rod with several rubber stops that when you operated the expansion nut it create a seal against water pressures up to 80 psig. This tool is no longer available but a better one can be purchased. It is more versatile a little pricey for a home owner but great for a service contractor. See attachment.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron1
- 125 Chimneys & Flues
