Issue with Rheem 62-22694-11 Control board
Hello to all,
I have a problem with both heating and cooling. My unit is a Rheem Criterion. No power to a Honeywell mechanical mercury Thermostat. Even when I jumper the switch to make the fan/AC/heat come on, nothing happens. Symptoms are as follows:
Breaker is good.... nothing thrown. Unit receives power.
Rheem Criterion has the 62-22694-11 control board. Both the "PWR" and "OK" LED light up when the blower door button is depressed.....yet at the thermostat, I have no power.
Is there a fuse on the 62-22694-11 that I am missing?
Do I need to replace the 62-22694-11 even though it is showing it has power and is OK?
Thank you for your input
Regards,
Kyle
  • Zman
    Zman Member Posts: 7,614
    Have you tried jumping terminals on the board or checking power at the board. A good first step is to eliminate the t-stat and t-stat wiring as the cause.
    Albert Einstein
  • K_Rogers
    K_Rogers Member Posts: 3
    I was thinking that the board had power because of the LED being lit. I haven't tried jumping the terminals on the board. Will comment with the results. BRB
  • K_Rogers
    This is what I found out:
    On the board :
    Jumper Red and Green will make the fan come on and stay on. No issues.
    Jumper the the Red and Yellow nothing happens - just a hum.
    Tie into the Red and touch the Yellow, it will spark then the fan will come on. AC never comes on, then the fan will stop.
    hmmmmmmm.
    HVACNUT Member Posts: 7,526
    The hum might be the condenser coming on without the fan.
    What happens R to W? It should run the heat cycle.
    At this point it looks like the board is good. Check the thermostat wiring and thermostat.
