Question Regarding Old Model Packaged Heat Pumps
Por
Member Posts: 3
Does anybody know if any company still sells packaged heat pumps with the supply on the right, and the output on the left, while facing the vents.
I have been looking online and all over the place, couldn't find one.
return on right or supply on right?0
Sorry about the confusion, the Supply is on the right while facing the duct openings. The more current ones all have the supply duct opening on the left while facing the openings, and I need to look for one that still has the supply on the right side. Thank You0
What's the model number of the existing one?
How 'bout a few pics of it? Maybe some suggestions could be made.
This is a Trane XL16c. I cant find a spec sheet but it looks like a right side supply.0
That's like every new unit that I've seen. The supply is on the left when facing the unit's duct openings.HVACNUT said:This is a Trane XL16c. I cant find a spec sheet but it looks like a right side supply.
Bob Boan
Every unit that I know about made in the last 15+ years, has the duct connections the same way: supply on the left, return on the right when facing the duct openings on the unit.
Maybe someone else knows of something different, but you're probably gonna have to criss cross the ducts.Bob Boan
Have you called Trane to see if they have a current offering?
Actually, I recognize that layout. 60-80% sure it was a Carrier (or Bryant). I've installed that style of Trane (or possibly American Standard) as well.
You should be able to get one fairly easily, you'll need to talk to a rep though. Are you a home- or business-owner, or a contractor? Where are you located?
Is this on a roof somewhere, or ground mounted? You can always get a curb adapter to make something else fit onto the existing curb.
Thank you for the help. I think I will just have to call Trane to see if they still offer those older models.0
Most units have a bottom as well as side S/R's. You may be able to raise unit and come out the bottom with one or both ducts.0
- 129 Chimneys & Flues
- 122 Geothermal
