Control for fractional HP motor needed
Does anyone know of a control, or an Inexpensive VFD that could be used on a 115 volt 1/10 hp motor? The application is an an exhaust fan for a lab that is served by a VAV box. The board in the vav box would send a 0-10 volt signal to the exhaust fan’s control, the signal would increase as the damper in the box opens. A vfd may be the only way to go, but the fan is so small that this me be overkill. I did not know if anyone had a like experience, and what control they used for this. Thanks to all
    Jamie Hall Member Posts: 27,582
    Is this a standard AC squirrel cage motor? If it is, the speed it runs is fixed by the frequency of the power fed to it, so a variable frequency drive is going to be the only hope. If it is the type with brushes, you might be able to control the speed by varying the voltage applied (think Lionel electric model trains!).
    EBEBRATT-Ed Member Posts: 20,481
    120 volt VFDs are available, mostly Chinese made.
    zepfan
  • zepfan
    zepfan Member Posts: 467
    Thanks for the responses. We have not received the motor yet and the submitalls do not state weather it is PSC, shaded pole, or ec. Normally we would use a wall mounted scr to very the speed of the fan, but that requires manual adjustment. We are looking for something that is automatic
  • Jolly Bodger
    Jolly Bodger Member Posts: 209
    What type of lab? Sounds like you need to keep the room negative. Seems like a 1/10hp motor might be small for controlling space pressure. I have come across some of the newer ECM motors have a 0-10 input.
    zepfan
    pecmsg Member Posts: 7,282
    Not a very big exhaust fan. If a squirrel cage fan just control a damper.
    hot_rod Member Posts: 27,846
    a trial relay might be all you need, if you have a way to send it a signal. 20 bucks or so for a small relay able to switch 1 hp or so. We added them to our solar controllers when the load exceeded 1 A.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    Modulating damper tied directly to VAV.
    Honestly for a fan that small, just leave it running.
