No heat electrical?
Awoke this morning to no heat. The flu was struggling to open on my national gas steam boiler making a humming sound from the transformer on the right side and best of all, there is no spark or flame no way of testing it with a lighter since it's an ignition system any ideas?
    Jamie Hall Member Posts: 27,519
    You say the flue was struggling to open? By that, do you mean a powered damper on the flue pipe from the boiler to the chimney? If so, it has to open -- fully -- before the boiler's burner can get any power at all. There should be a way to open it and lock it open manually. Then the boiler should fire.
  • hankwylerjr
    hankwylerjr Member Posts: 158
    edited January 2020
    @Jamie Hall I opened it but still no flame could it be the rollout switch
  • Zman
    Zman Member Posts: 7,614
    Do you have a multimeter?
    You should be able to work your way around the safety circuit and see which switch is staying open.
    Albert Einstein
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,617
    Could be lots of things. You need to know how the circuits are set up and how to use a Multimeter. If not it might be advisable to hire a professional
    B_Sloane
  • hankwylerjr
    Before I left to get the Volt meter at the garage I realized that I should check the reset on the switch it tripped due to a door being open maybe a draft but all is well
