Saving a bit of heat.
Daveinscranton
Member Posts: 148
I live on a hill top. Brutal wind. Not so in the valley. Anyhow, all night long I could hear the flapper plastic door/valves swing open sucking out heat from my bathroom vent fans. (When the fans were off).
So I put in 24vac power dampers on relays activated by the bathroom fan on 120v. Problem solved. Prior to that I had 2 four inch holes in the house venting heat into the outside. It has probably been covered before. If so, I apologize.
Now, when the bathroom fan runs, unimpeded exhaust to outside. Fan off = sealed drum tight.
On my 3, or 4 th year. Maybe more. Works great in a tight house. ICF construction with radiant floor heat.
Thank you,
Dave
Thank you,
Dave
2
Great idea. Also keeps precipitation out (blowing snow, or rain) on the roof type vents when not in use.0
Most modern bath fans have a damper built into the fan housing. The terminal cap also has a damper. While I like the concept of a powered stack damper, the headache factor might not be worth the effort?
Icarus0 -
Hi, I installed just that motorized damper on my kitchen exhaust about 15 years ago and it still is going strong. Perhaps I don’t cook enough
Yours, Larry0 -
What’s happened with one bath fan a couple times, is snow blows in the exterior housing. Lays in the duct, and doesn’t melt. Until you take a shower with the fan going. The secondary flapper is open the snow melts, and runs all over the bathroom floor.0
Mine are under a deep soffit so haven’t noticed. I wonder if vents on a wall face get more updrafts and flip them open?
I did like the central exhaust fan design better.
When in stalled central air, I almost went with mini splits for the 4 main bedrooms and use a continuous ERV to vent & pull conditioned air into the bathrooms.0 -
Be careful with a ICF sealed home that its not too tight.
Every home should have a complete air change every 6-8 hours too stay healthy and exhaust indoor pollutants!0 -
That's a good idea ..... my last two projects have used the external mount Fantech unit -- that still requires a damper .... but the units fan design limits the backflow.
On a big kitchen exhaust -- it's a very good idea .... as long as you can clean it0 -
These are under a 4 foot roof overhang. For whatever reason, nothing was keeping the vents (original) closed in the wind. I think it is a fluke situation of the house orientation and prevailing winds.
Works great. I had most of the parts so no big expense. Maybe 4 hours tops in the attic. Maintenance free for years (so far).
I love the kitchen stove vent idea. I love stuff like this more when I make it of discarded parts.0
