Why Steam Vents Die
HeatingHelp
HeatingHelp Posts: 736
edited September 2019 in THE MAIN WALL
Why Steam Vents Die
You shouldn’t hear vents venting. It’s not a good sound.
Read the full story here
Mad Dog_2
  • Never heard a plug described that was! Good One!!!
    joeshrapnel
  • Shalom
    Shalom Posts: 165
    When I was a kid, I remember hearing when the steam came up, the vents would go "Psshhhhh ...... toink!" Always a sharp onset, and a sharp cutoff. I guess the onset was when the main vent slammed shut. G_d only knows what pressure he had that boiler set to, but gas was cheap in them days.
    Oh, and "First Aid For The Ailing House" was his bible.
    Mad Dog_2
  • mikeg2015
    mikeg2015 Posts: 1,194
    When I bought my house it has a little Hoffman 76 or maybe #6 vacuum vent original form 1905. It was green from oxidationand had rust all over it from spitting out water for decades. IT probably wasn’t plugged because they couldn’t remove it.
  • Not to be a devil's advocate, but the above is a good argument for hot water vs. steam, at least for residential applications. Think about how a steam system works: get the inside of the system good and hot; get it wet; suck in some air and let it cool; repeat thousands of times. If you wanted to create a factory to manufacture and sell rust you could base it on a steam heating system. I recently removed a gravity hot water boiler that had to be 100 years old. How many 100 year old steam boilers are still working? (Sorry - I know you are a steam fan, but couldn't help myself.)
    Corktown
    ethicalpaul Posts: 9,021
    They probably all are, except the ones that got torn out by people who didn't want to understand how well they work.
    CorktownRTW
  • The boiler in my building is 93 right now....
    Corktown
    Jamie Hall Posts: 27,878
    And might I ask how many 100 year old hot water boilers are working? Didn't think so. Never mind pumps...
    With a small amount of maintenance, a steam system's components will last a good long time. I can't calculate a mean time between failure for the traps on the system in the main house I care for, for instance, because they've only been operating for 90 years without any failures. I did add another main vent to the system, to add to the Hoffman #75 which is also 90 years old, only because with Hoffman didn't have as much venting capacity as I wanted. And I did have to replace a wet return which was rusted out from the outside... from long contact with a coal pile.
    CorktownMad Dog_2
  • At NEFI School in the 1950's the Smith-Mills Rep claimed they had just renovated an 1835 Mills Boiler. It was in a Southern Cotton Mill and had been fired by wood, coal, peat moss, corn stover, cotton waste and whatever . He claimed then the longest operating boiler in North America. Wonder if it is still around ..... ?
    (I have a 1935 International Heater, Ithaca, NY, Economy #64 Wood Burner integrated into my W/M Oil System.)
    CorktownMad Dog_2
  • bowman
    bowman Posts: 20
    A while back, I posted a Wall question on cleaning vents.
    I took the advice offered and used white vinegar with great success.
    I wrapped the vent holes with painter's tape, filled them with white vinegar, then propped them and let them sit overnight.
    A lot of rust came out when I turned them back upright and rinsed them out.
    Where I am located, a bottle of vinegar is cheaper than a new vent.
    CorktownjoeshrapnelMad Dog_2RTW
  • JoshP
    JoshP Posts: 133
    92 year old steam system With about a 65 year old American standard boiler still going strong in Utica Ny. Most of the homes on my street have steam systems too
    Mad Dog_2RTW
  • We likewise have an American Standard (Capitol) boiler size # 247) that was installed approximately 1918 so this makes it 101 years old. It has a Roterts Gordon gas conversion and still going strong in Ithaca New York. They sure don't make them like they used to! However, we did have the same exact boiler at another location that failed a couple of years ago. So I guess the moral of the story is these old baby's can ultimately fail but it can sure take a while.
  • jayvath
    jayvath Posts: 3
    After installing a tekmar Smart Steam Control 289 with a Pressure Sensor 089 on a steam heating system, we observed that the system would record a negative pressure reading via the Nexa web or mobile app. The vacuum (negative pressure) was a result of clogged main air vents not allowing air back in when the system cooled.
    Most pressure gauges have a pin to prevent the needle from indicating a negative pressure so clogged air vents are difficult to detect.
    Corktown
  • patrykrebisz
    patrykrebisz Posts: 151
    if you put your mouth to any new vent and start blowing air lightly through it, you WILL hear a sound. this is a function of physics. reading that statement in Dan's book has confused me to no ends.
    air vants have a tiny opening. air moving through it, WILL produce a sound.
    i understand the sentiment. we shouldn't be hearing a tornado-quality sounds coming out of the vents but they are far from being quiet.
    joeshrapnelCorktown
  • jumper
    jumper Posts: 2,618
    Modern homeowners don't do maintenance and steam boilers supposedly need it regularly? OTOH LostArt mentions vapor systems that have chugged on for decades. Don't they use air eliminators different from vents? Also it isn't difficult or expensive to rig up redundant low level safeties.
