Search comments by user
SENWiEco
SENWiEco Member Posts: 164
Is there a way to search the archives for comments from specific users? Or view all of a users comment activity?
Sean Wiens
    Jamie Hall Member Posts: 26,837
    If you type the user's handle into the search box (upper right corner) it will come up with all the comments in which that user was referenced. Don't think that's what you're looking for, though, but usually is someone is referenced in a comment, chances are pretty good that they themselves will have made a comment somewhere earlier in the thread.
    @Erin Holohan Haskell ?
    SENWiEco
  • SENWiEco
    Thanks @Jamie Hall You are right in understanding what I am after. Your work around is something I do now, but takes a lot of time to find the relevant comments I am after. I want to find comments from power users on specific subjects.
    Cheers
    Sean Wiens
  • ratio
    ratio Member Posts: 4,176
    If you click on a user name, it takes you to their profile page. On the right under "activity" is "comments", which I think is every comment they made. Is that what you're looking for?
    SENWiEco
  • Leon82
    Leon82 Member Posts: 684
    edited June 2019
    In Google you can use your search criteria and site:heatinghelp.com. (I think that's the right combo
    This goes for any site
    User username site: heatinghelp.com
    for example
    SENWiEco
  • SENWiEco
    Hi @ratio, that is exactly what I was after. Thanks so much!
    Sean Wiens
  • SENWiEco
    Hi @Leon82, thanks for follow up. Yes this is a great utility I have often used. But not what I was after in this case. @Ratio provided the answer I needed.
    Sean Wiens
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Thanks, @ratio!
    President
    HeatingHelp.com
