Testo 320 question
Takdashark
Hello all,
I have a 320 that was recently serviced at Testo. I was doing a combustion test the other day and noticed that the readings changed if I placed the analyzer in a horizontal vs vertical position.
I never noticed this before, but I usually find a good spot for it and leave it. The magnets aren’t the best and it recently slipped down a pipe and the screen landed on a draw off and cracked. So I’m a little more cautious as to where I place it now.
Anyone have any input on this? I haven’t called Testo yet, but I figured some real world input would be nice.
Thank you!
Taki,
Thank you!
Taki,
How much did it change? Have you checked to be sure the lines and filters are clean. I have the same model and will check the next time I use it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I wonder if in horizontal it's slightly pinching the tubes. I know Bacharach recommends vertical, letting the tubes hang, free of pinching or kinks.
I had something similar with a Magnahelic, the readings changed if I moved the gauge. Chased it down to a drop of water in one of the lines—threw everything off.
I was pulling my hair out for a while!
They change quite a bit, over a percent. I swear it didn’t do it before! I called Testo and first the tech said it was out of calibration. But it was calibrated by them less than 6 months ago and has been used a dozen times on residential condensing gas boilers on tune ups.
I did remove everything and check for water in the lines.
Now I’m starting to question any adjustments I made to the last few systems I worked on.
I’ll will update as thing go along. Thanks for the replies!0 -
Do you have access (buddy?) to another analyzer where you can go side by side to check?
I did have a older 320 do the same thing, I too was concerned. It is now my back up have a new 320. Never put the two side by side for a test. Will do no time for that this winter, maybe later will do a comparison. Just didn't trust it when I seen it do that trick, one needs to trust our test instruments, hence bought new.
D
I do have a access to buddies analyzer, but as mentioned above it’s trying to find the time to get together to do it.
After another call to Testo I was told to replace the O2 sensor. I ordered one, if I don’t feel confident after that I will have to pull the trigger on a new one. Last time I sent mine out to Testo in Jan they had for a month. That’s too long to be without an analyzer, especially in the winter.0
- 133 Chimneys & Flues
