Glycol
BFlanzbaum
BFlanzbaum Member Posts: 26
edited February 2019 in THE MAIN WALL
So I need to drain a building of 2500 gallons of glycol, repair some pie and reinstall the glycol. Any company's , ideas suggestions on who I could get or rent a tank from in NJ? Thanks
    pecmsg Member Posts: 6,781
    That's a lot of glycol to fix a leak?
    Any Tanker Truck Services in the area?
    hot_rod Member Posts: 26,594
    Test it to make sure it is worth saving and reusing, the ph in the 7's is an indication that it needs to be replaced or boosted.
  • butcherpete
    butcherpete Member Posts: 19
    Can't just isolate the section and work on.
    That is what i do
    I have a couple of 550 gallon tanks for big sections.
    But usually 10) 55 gallon barrells do the trick.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    If you call most chemical suppliers or recycling companies, you can get “clean” empty IBC totes of glycol delivered with a deposit. Be sure ot always label the totes properly before you fill them for safety reasons.
    But a mentioned, 55 gallon barrels could be easier. Your call. But I’d probably rent a forklift and just use 4-5 large totes. You can stack them 2 high to save space.
    Zman
