Manometer brand suggestion.
Intplm.
Member Posts: 3,069
in Gas Heating
I am looking to buy a manometer. What brand Manometer should I purchase? I haven't purchased or used one in years and the one I had is M.I.A. I don't plan on using it much but find that I need one.
I'm thinking it's long over due that I go digital0
I really like the Fieldpiece SDMN6 I picked up after my SDMN5 came up missing. I also have a selection of Dwyer Magnehelics that I use for assorted air-side measurements, and one with a Buna-N diaphragm for use on natural gas.2
Yep. Like I said, I like it & the one it's based on. It's a little sensitive to temperature, you'll want to zero it frequently, but even with that it's an overall winner.
Comes with a nice carry bag & a handful of very useful accessories, in particular the adapters to nipple on to the gas valves that have a teat with a li'l Allen set screw in the bottom instead of the usual 1/8 NTP port. (Protip: just crack them a half turn or so, you don't need to take them out!) Another adapter that I use all the time is a β3" x 1/8 NTP nipple to get on to the test ports when the mfgr has thoughtfully put obstructions around the gas valve.
1 -
+1 for SDMN6.
The main reason I love the fieldpiece is each pressure port is itβs own pressure sensor. So I can use that one manometer to check two separate pressures at once. I had the UEI before this one, and it had only once sensor with a dedicated + and - port.
I carry the SDMN6 with me and have an SDMN5 in the truck. Nice for setting up four stage RBI and Lochinvar water heaters. Can set all four pressures with only two manometers.Never stop learning.2 -
I use a Testo digital. Once every blue moon I will tee into a water tube and do a little diagnostic testing and the Testo is nails. Spot on compared to the water.1
@Mike_Sheppard, that's similar to what originally prompted me to get the '6 & the Buna-N Magnehelic, setting four gas valves & monitoring inlet pressure on a few 50 ton Lennox RTUs. Having a hot spare for when my '5 came up missing was a side benefit.
Sure did make the commissioning go fast though.
1 -
I bought UEI the first time ...
Don't !!
Since then I purchased several Dwyer electronics, both are now 10+ years old
I use them weekly0
- 125 Chimneys & Flues
