A nice letter
Henry
Member Posts: 998
Could you forward me the article on dirtmag by email or pm?0
Thank you, @Henry, for paying it forward to the next generation. That's so nice of you.
President
HeatingHelp.com1 -
The books that I have read several times in over 43 years have also taught me about one pipe gravity hot water and one pipe steam vacuum assisted among other things.0
WOW!0 -
One pipe gravity feeds to the top of the building. Then has down feed reverse riser. To feed a radiator, it has two Y fittings with one feeding and the other removing water for a radiator. The Northern Telecom building which was 11 stories tall used this system here. It had a separate building for the large boilers which I don't remember the number. I do remember that they replaced the boilers for copper fin and put pumps. It was a $2million screw up. I consulted on having the boiler room on the roof to use the existing horizontal distribution to the reverse risers. That worked. BTW multiple condensing boilers were used with outdoor reset which was able to micromanage the heat load.
- 119 Geothermal
- 394 Solar
