Carbon Monoxide monitor in boiler room or just outside? Bedroom overhead boiler room.
bipbap
bipbap Member Posts: 233
I was wondering what is recommended.
We have a single pipe steam heat system with gas boiler and two gas water heaters in a boiler room which happens to be located directly underneath our baby's bedroom.
I don't know how risky this situation even is, but my mind started wandering...
What sort of safety would be recommended?
We obviously will have a carbon monitor in his room, but what else?
Carbon monoxide monitor INSIDE the boiler room? Just outside the room?
Any ideas are welcome, thank you!
    Jamie Hall Member Posts: 27,382
    CO monitor in the boiler room, with a loud enough alarm to wake you up wherever in the house you might be. Should be there anyway, baby or no.
    pecmsg Member Posts: 7,066
    Search for Low Level CO Monators for the baby’s room.
    Standard Monators alarm at too high a level 70 PPM For 1Hr.
    Low Level alarm at 5 PPM
  • SlamDunk
    SlamDunk Member Posts: 1,807
    edited January 2019
    i do both.
    co/ methane detector in basement, co / smoke detectors in bedrooms.
    But just as important: regular maintenance, inspection and combustion analysis.
    EBEBRATT-Ed Member Posts: 20,197
    smoke/fire alarms should be their too. You can get combination Co & smoke or use separate Co & smoke
