Expansion Tank: does 2 = 1 + 1?
It seems that my system needs a rather large (50 litres) expansion tank, for which I don't really have room. Is it possible to use, instead, two 25 litre tanks? In parallel? In series?
  • Ironman
    Ironman Member Posts: 7,858
    In parallel, but connected at the same point to the system.
    Bob Boan
    Jamie Hall Member Posts: 26,839
    And be certain that you have as nearly as possible exactly the same air pressure in both tanks.
    delta T
  • Gordy
    Gordy Member Posts: 9,546
    Yes with the above requirements, and installed so the circulator is pumping away from them, and on the supply side of the boiler.
    Steamhead Member Posts: 18,205
    What Ironman, Jamie and Gordy said. We've done it.
    Consulting
  • Gordy
    I would have to rephrase the supply side of the boiler. Since some modcons like to be pumped into the boiler, or return side of boiler.
