Wireless thermostats
Now for my $64K question. Since thermostats can be controlled remotely via phones. Why not have a thermostat trigger a switch at the boiler to go on/off via the same technology? Does such a system exist? It would enable me to avoid an expensive rewiring job.
Thanks for any suggestions / ideas.
No problem. It's called a relay... the relay is controlled by the wireless thermostat (and the whole thing will need an appropriate 24 volt supply and wiring and all) and it in turn controls the heating system.Br. Jamie, osb
I hope you have line voltage thermostats and not high voltage
But @Jamie Hall has pointed you in the right direction. There was an error rendering this rich post.
From your other thread, I don't think you're explaining your situation correctly. Your A/C company proposed to install a WiFi thermostat, not wireless, correct? You would like to convert your heating system to low low voltage control circuits so as to merge your A/C and heat (1 zone) into one thermostat.
The 4 figure estimate you got from your oil company, sounds like they want to go wireless with an interface module for your 2 heat zones. You would still have to use a seperate A/C thermostat.
Like @JUGHNE said on June 27th, the A/C company should have a tech. with controls knowledge. Ask and get an estimate, or better yet, click "find a contractor in your area" at the top of the page and get an estimate for your A/C and boiler controls conversion.0 -
wifi needs 24 volts to work and so does the wifi t stat, hope that makes sense? most need 4 wires but you need more if its heat and cool, pull a 7 wire"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Thanks, but I need to revise my inquiry.
I am looking for a means of communicating from the thermostat to the boiler without wires.
The oil company tech told me I would need a new run of wires to accommodate the wifi thermostat and 24 volt configuration (this was with a burdensome cost).
As result, am now seeking solution that would NOT REQUIRE rewiring from thermostat to boiler. Does such an arrangement exist?0 -
Not that I'm aware of as any sort of stock item. I dare say that a good geek could probably rig something involving an Arduino or two and some additional components and some relays...Bigdaddrock said:Thanks, but I need to revise my inquiry.
As result, am now seeking solution that would NOT REQUIRE rewiring from thermostat to boiler. Does such an arrangement exist?Br. Jamie, osb
Well, you can have a RedLINK (Honeywell's wireless brand) thermostat that will communicate to an equipment module and a RedLINK gateway that plugs into your home router. That still leaves a relay or something between the equipment module (which is designed to control low voltage equipment) & the line voltage controls of the boiler. Shouldn't be too difficult. Honeywell even has a demo of the phone app—search for "Honeywell Total Connect Comfort" & see if it's what you're looking for.-1
As Jamie Hall indicated, I don't think the solution you are seeking exists. What's more, it's got to be a whole lot cheaper and more reliable to purchase a roll of thermostat wire and do a little drilling and drywall patching to get the wire from the thermostat to the boiler than to set up wireless switching.0
ratio said:
Well, you can have a RedLINK (Honeywell's wireless brand) thermostat that will communicate to an equipment module and a RedLINK gateway that plugs into your home router. That still leaves a relay or something between the equipment module (which is designed to control low voltage equipment) & the line voltage controls of the boiler. Shouldn't be too difficult. Honeywell even has a demo of the phone app—search for "Honeywell Total Connect Comfort" & see if it's what you're looking for.</blockquote
Listen to Ratio..... he's right on.
I've sold numerous Redlink wireless systems and they work well. Find someone in your area familiar with the technology. They aren't that difficult but can be for someone who has no experience with them.Terry O0 -
I stand corrected on the wireless solution. RedLINK looks like a real useful solution for the issue Bigdaddrock is facing.0
Yeah, I'm forced to not dislike it, as it's been nothing but reliable for me. A RedLINK 6000 kit is my go-to for the oops-we-need-wireless jobs.0
The Vision Pro line uses Redlink communications. Get a Vision Pro for the wall, it communicates wirelessly with the equipment module. Can get a WiFi Gateway to control stuff by an app or PC.0
- 120 Geothermal
