Steam Boiler Comparison help
124»
  • ChrisJ
    ChrisJ Member Posts: 17,663
    *Moot.
  • mynameisphunk
    mynameisphunk Member Posts: 46
    Now to order insulation for the mains!
    If you are doing it yourself, use 1-1/2". You'll thank me.
    Already bought 1" based on multiple threads I read up on here - as well as what I have room for between the mains and the floor joists. Even 1" won't fit in several places.
    It will be probably be good enough - and the basement is going to be turned into a semi-finished living space so a bit of heat loss from the mains won't be the end of the world.
    Even now with them almost completely unininsulated, the basement does not get uncomfortably warm.
