ProPress vs Sweat
I have both sausage fingers, and am learning to work on clocks as a hobby.Canucker said:
So........... sausage fingers and fine delicate work can mix.
So there! Sausage finger people unite!
2 -
Almost as much fun is changing surface mount IC's on a PWB without reflow equipment. I usually use a magnifying lamp and a magnifying visor so I can see the bitty pins. Then I try to time the soldering iron movements with my hand tremors to get the thing soldered without shorting anything out.
3PSI gauge1 -
Ever done BGA by hand?BobC said:Almost as much fun is changing surface mount IC's on a PWB without reflow equipment. I usually use a magnifying lamp and a magnifying visor so I can see the bitty pins. Then I try to time the soldering iron movements with my hand tremors to get the thing soldered without shorting anything out.
BobSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
At my stage of life I can't see them so I just ignore them, 16 pin SOIC's are pretty much my limit.
3PSI gauge0 -
16 SOIC!?BobC said:At my stage of life I can't see them so I just ignore them, 16 pin SOIC's are pretty much my limit.
Bob
That's huge!
Chips like these are a bit challenging.
0402 and 0201 passives are also fun.
Since website features came up, using Safari for iOS, when I click "quote" the post isn't copied into the new comment box. Instead, "null" shows up in the comment box. Maybe I need to reset something?0
I've always had the same issue on Android as well.BigRob said:Since website features came up, using Safari for iOS, when I click "quote" the post isn't copied into the new comment box. Instead, "null" shows up in the comment box. Maybe I need to reset something?
Basically, quoting only seems to work on a desktop machine. Not sure why.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
1 -
Not to drag this any further off topic, but do you have an opinion on how well the auto route works on the various free board layout packages? I've on occasion in the past wanted to make a few one-offs, not much more complicated than following the reference design, but I don't have the depth of skill to do a custom layout.0
Sorry no help here, my last layout was done with tape on mylar! I pretty much stick to vero board and I'm not even sure if they are still around.
3PSI gauge0 -
Can't help sorry.ratio said:Not to drag this any further off topic, but do you have an opinion on how well the auto route works on the various free board layout packages? I've on occasion in the past wanted to make a few one-offs, not much more complicated than following the reference design, but I don't have the depth of skill to do a custom layout.
We have a guy where I work that does all of that and the last boards I did my self I paid a friend to lay out for me.
I'm going to guess auto layout probably works for simple things, and doesn't work for most.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@BigRob, yes, my last post to you was from Safari for iOS and I didn't run into issues. Please try clearing your browser cache and send me a message to let me know if that works. Thanks!
President
HeatingHelp.com0 -
After bragging about all the tiny things worked on does the collective still need a shift of radio buttons?0
I don't see any radio buttons, and yes.Gordy said:After bragging about all the tiny things worked on does the collective still need a shift of radio buttons?
However as Erin already mentioned, it's not possible so people need to be more careful.
Here's a couple of pics of a Pro-Press job I sold to one of my customers. It doesn't get much better than this. Done by a real professional. I quoted him in Pro-Press and solder fittings. Although the cost of solder was much lower than Pro-Press, the labor time was substantially lower than soldering. He didn't have one leak out of the hundreds of fittings installed.2
Installed many Viega valves only to have them fail in 2 years or less, Don't use!0
@lza
Not a fan of PP but you answered your own question. Propress. The old valve is leaking by.
Even with the excessive cost of PP fittings putting in a PP valve will be much less cost overall0 -
They both work fine."Don't try to win an argument; instead, try to have a conversation." -Steve Deace0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
