Ignitor isn't firing
AlecD
Member Posts: 2
in Gas Heating
I have an older Rheem combo unit. Last year we had the heat exchanger replaced and we had blazing hot heat. I just tried to turn on the unit and only 2 of the 3 gas ignitors is firing.
Can I test the ignitor? I assume I would test for continuity to verify that the ignitor isn't somehow broken.
Can I use a propane torch to light the gas in that chamber to verify that gas is coming out?
Will I be able to buy a replacement ignitor without an HVAC license?
I believe you are
talking about the burners not igniters. Typically there is only one igniter on a furnace or boiler bur several burners. I would have a professional take a look at it as you are having a definite combustion issue.0 -
Right.
Yes.
I didn't take a very close look the first time and assumed there were 3 ignitors.
The ignitior is on the far left burner and the far right burner wasn't igniting. The bleedover from burner 1 to burner 2 was happening, but it wasn't happening from burner 2 to burner 3.
I tapped on the space between burner 2 and 3 and then it bled over and lit up burner 3. Must have been some corrosion or something built up in that space.
If this continues to be a problem, can I find the burners and install them myself?0 -
Beware.....
I understand you want to attack this problem yourself, but call your professional tech. Are you sure the orifices arent plugged? You can buy new burners and still have the same problem. This is also how home owners get hurt and or killed. Dont skip on safety,....I'm tired of reading in the paper that people are getting hurt or even dead because of lack of maintenance.....NO JOKE
Mike T.0
- 117.3K All Categories
- 82.7K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 400 Carbon Monoxide Awareness
- 7 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 106 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 674 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.2K Strictly Steam
- 2.9K Thermostats and Controls
- 47 Water Quality
- 31 Industry Classes
- 64 Job Opportunities
- 11 Recall Announcements
