The I=B=R Book
Boston Standard_2
Member Posts: 10
Do you know where I can buy this book? I received it in a seminar years ago and now want to give it to my apprentices for Christmas! Thanks, Joe
Don't Know
Where to find that but Modern Hydronic Heating 3 by John Siegenthaler which can be found here in Dans Store is fabulous. Takes you from what is hydronics to heat loss, types of boilers and everything else you can think of. I'm sure you will get the same feedback from all that regularly post here.There was an error rendering this rich post.
I=B=R
There were a couple of them - green and blue vinyl folders. I've got them stashed in my basement somewhere. At the time, they were one of the few sources of hydronic heating information in this country.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Good luck with that...
IBR was absorbed by GAMA a long time ago. Ithink it is now referred to as the Hydronics Institute division of GAMA. I tried going to thier web site to find the books to no avail...
The last time they actually held an IBR class was back in 04, I believe. You might be better off dropping it to Kinkos and have them make a copy of it and bind it for you.
METhere was an error rendering this rich post.
It's available in our Store.
http://www.heatinghelp.com/products/Hot-Water-Heating-Books/26/65/Residential-Hydronic-Heating-The-I-B-R-CoursebookRetired and loving it.0 -
Sorry Dan...
I was under the impression he was looking for the "Old School" books :-)
In any case, your outlet is a wealth of knowledge and information, regardless of the person/organization writing it.
Does anyone know whats going on with the schools that IBR use to sponsor? Seems like a substantial loss in the world of education.
Thanks for all you do sir.
Thanks, Mark.
We've sold so many copies of that book. Jim Goins did the graphics and it's a terrific primer. I think it's much better than what they produced in the old days.
I don't hear any talk of revising the school, but I'll keep listening.Retired and loving it.0 -
Dan,
Is there just a limited supply or will the book continue to be available in the future?Bob Boan
Thanks for the help!
I appreciate the help- thanks very much, JoeThere was an error rendering this rich post.
IBR Books:
Dan,
I had multiple copies of the old IBR books. The H-22 heat loss guide with the gray cover and the yellow one that I think was #240 advanced guide. Then, there was an orange one that did radiant.
I foolishly loaned one copy of the H-22 Heat Loss Guide and the Yellow #240 one. I never got them back. The one I miss is the Yellow one that is now #250. It combines the orange and the yellow and leaves out a lot of good stuff that I always used. Any chance you know where I could get a yellow copy?
The H-22 heat loss guide new version is a PITA too. It's like ACCA and ASHRA blew up on it. I consider it (the old one) perfect for Wet Heads. Air Heads will never use it, so why bother.
Your thoughts?0 -
I checked my shelves, but I don't have that one.
Maybe someone else will respond. Start a new thread with it as the subject and let's see.Retired and loving it.0 -
As far as I know, there's no limit to the supply.
Thanks.Retired and loving it.0 -
Excellent!
That should make Chris happy.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It pays to
wander off the Wall sometimes.That I-B-R manual is excellent, I use it in all my classes. Once they have that and some of Dan's books under their belts then get "Siggys" book as a final read.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
