who makes...
an 18" flue damper?
  • Ken_8
    Ken_8 Posts: 1,640
    Sorry,
    I thought you were referring to a draft regulator.
    "Never mind..."
  • J.C.A._3
    J.C.A._3 Posts: 2,980
    My Hero....
    I think I'll keep him.(let's see if we can make this go over 50 posts!) Fun , Ain't it? Chris
  • John S.
    John S. Posts: 260
    it's for replacement.
    I can't find any mfr on the damper itself, however, the motor and controls are all there. Had a relay switch or two go bad and the electrician would (obviously) like a wiring diagram for it. The motor is Honeywell but the other side I do not know. For the time being, the damper has just been secured open.
    Thanks for the mfr names.
    J.C.A.,
    5 down, 45 to go:)
  • Honeywell motor?
    Maybe Flair mfg.?
  • 18\" damper
    Did you try Wing?
  • John S.
    John S. Posts: 260
    Thanks all for your help!
    I finally found the paperwork for it buried in a file cabinet. It's an 18" EnergyVent.
