who makes...
John S.
an 18" flue damper?
Sorry,
I thought you were referring to a draft regulator.
"Never mind..."0 -
My Hero....
I think I'll keep him.(let's see if we can make this go over 50 posts!) Fun , Ain't it? Chris0 -
it's for replacement.
I can't find any mfr on the damper itself, however, the motor and controls are all there. Had a relay switch or two go bad and the electrician would (obviously) like a wiring diagram for it. The motor is Honeywell but the other side I do not know. For the time being, the damper has just been secured open.
Thanks for the mfr names.
J.C.A.,
5 down, 45 to go:)
Honeywell motor?
Maybe Flair mfg.?0 -
18\" damper
Did you try Wing?0 -
Thanks all for your help!
I finally found the paperwork for it buried in a file cabinet. It's an 18" EnergyVent.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
