Pipe cement for concentric vent
Ed_26
Ed_26 Member Posts: 284
Note: Gas code changes as of july/07 requires use of Certified pvc materials & cements/primers for gas fired equipment (B.C. for sure), I think most provinces also. Better check with AHJ (local gas branch inspector)
  • Nikolai
    Nikolai Member Posts: 31
    Installation instruction for Concentric vent (in Canada)
    .. construct all combustion air and vent pipes for this unit of CSA or ULC certified Schedule 40PVC, PVC-DWV, or ABS-DWV pipe and pipe cement.... I am looking for advice
    regarding concentric vent cement. Thank you in advance.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Cement
    I've always seen gaskets on concentric vent. Who is the manufacturer?
  • hr
    hr Member Posts: 6,106
    PVC glue and primer
    it even comes in different colors these days.
    Generally the pipe supplier will also have the correct glue and primer for the materials they sell.
    hot rod
  • Nikolai
    Concentric Vent
    We use concentric vent for Trinity boiler and the concentric vent termination (NTI part number 82666) come from NTI, without gasket.
