Pipe cement for concentric vent
Ed_26
Member Posts: 284
Note: Gas code changes as of july/07 requires use of Certified pvc materials & cements/primers for gas fired equipment (B.C. for sure), I think most provinces also. Better check with AHJ (local gas branch inspector)
Installation instruction for Concentric vent (in Canada)
.. construct all combustion air and vent pipes for this unit of CSA or ULC certified Schedule 40PVC, PVC-DWV, or ABS-DWV pipe and pipe cement.... I am looking for advice
regarding concentric vent cement. Thank you in advance.0 -
Cement
I've always seen gaskets on concentric vent. Who is the manufacturer?0 -
PVC glue and primer
it even comes in different colors these days.
Generally the pipe supplier will also have the correct glue and primer for the materials they sell.
hot rod
Concentric Vent
We use concentric vent for Trinity boiler and the concentric vent termination (NTI part number 82666) come from NTI, without gasket.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
