Should I insulate the fresh air intake?
Tundra
Tundra Member Posts: 93
Do not insulate the combustion air. This will allow the combustion air to warm somewhat. You should use at least eight feet of 4" metal pipe on an outside air intake. I consistently use twice that with good results.
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    I have twenty feed of 4-inch steel ductwork that brings fresh air to my oil burner with a Fields Controls sleeve.
    Is it worth the money to insulate this pipe to prevent the heat drain?
    Is the boiler flame temperature any different when it is fed with 0* air versus 70* inside air? The thing I like is that the clothes dryer lint will no longer clog the burner vents.
    Steve from Denver, CO
    EBEBRATT-Ed Member Posts: 19,598
    Probably not mandatory that you insulate it if you are not getting condensation on it, Combustion is better if the air is warmer-but if you insulate it won't the air stay colder???
    Ed
  • Steve Garson_2
    Yes, the insulation will make the air colder. So since there is no condensation, sounds like I should leave it alone.
