Should I insulate the fresh air intake?
Tundra
Member Posts: 93
Do not insulate the combustion air. This will allow the combustion air to warm somewhat. You should use at least eight feet of 4" metal pipe on an outside air intake. I consistently use twice that with good results.
I have twenty feed of 4-inch steel ductwork that brings fresh air to my oil burner with a Fields Controls sleeve.
Is it worth the money to insulate this pipe to prevent the heat drain?
Is the boiler flame temperature any different when it is fed with 0* air versus 70* inside air? The thing I like is that the clothes dryer lint will no longer clog the burner vents.Steve from Denver, CO0 -
Probably not mandatory that you insulate it if you are not getting condensation on it, Combustion is better if the air is warmer-but if you insulate it won't the air stay colder???
Ed0 -
Yes, the insulation will make the air colder. So since there is no condensation, sounds like I should leave it alone.Steve from Denver, CO0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
