Spirovent Stuck Open
Pat_12
Pat_12 Member Posts: 27
Darin, Thanks for your input, I will take it apart this morning.
  • Pat_12
    Spirovent Stuck open ?
    My spirovent is stuck in the open position and is dumping water and reducing system pressure to zero. Is this piece fixable, or should I just replace. System is only a few months old. Thanks in advance for your help.
  • Darin Cook_3
    Darin Cook_3 Member Posts: 389
    Disassemble it
    There is a big float valve inside. Clean it up or you may have other problems going on. If you cannot take it down right now, screw a cap on it.
    Darin
  • hr
    hr Member Posts: 6,106
    This deep
    into a spiro is fairly easy. The top end is a lot trickier I'd replace it if the actual top vent is stuck. Lube the O-ring when you reassemble, they are known to leak :)
    hot rod
  • Larry_10
    Larry_10 Member Posts: 127
    spirotherm the company that makes it will give you a new one or fix it it has a 20 year warrantee on it try calling them.
    http://www.spirotherm.com/
  • jbplumber
    jbplumber Member Posts: 89
    Wack
    I have had 2 spirovents leaking on me and would not stop. I wacked the 1st with channellocks and it stopped so I did the same to the 2nd and it stopped.
  • Dave Stroman
    Dave Stroman Member Posts: 766
    This happens all the time with spirovents. Take just the top off and spray it out with carburetor cleaner. Smear the o ring with some pipe dope and put it back together.
    Dave in Denver
  • Pat_12
    Thanks to all
    Thanks for everyone's advice. I disassembled Spirovent and cleaned it. It seems to be working fine again. I will also call spirotherm and have them replace it.
