Spirovent Stuck Open
Pat_12
Member Posts: 27
Darin, Thanks for your input, I will take it apart this morning.
Spirovent Stuck open ?
My spirovent is stuck in the open position and is dumping water and reducing system pressure to zero. Is this piece fixable, or should I just replace. System is only a few months old. Thanks in advance for your help.0 -
Disassemble it
There is a big float valve inside. Clean it up or you may have other problems going on. If you cannot take it down right now, screw a cap on it.
Darin0 -
This deep
into a spiro is fairly easy. The top end is a lot trickier I'd replace it if the actual top vent is stuck. Lube the O-ring when you reassemble, they are known to leak
hot rod
spirotherm the company that makes it will give you a new one or fix it it has a 20 year warrantee on it try calling them.
http://www.spirotherm.com/0 -
Wack
I have had 2 spirovents leaking on me and would not stop. I wacked the 1st with channellocks and it stopped so I did the same to the 2nd and it stopped.0 -
This happens all the time with spirovents. Take just the top off and spray it out with carburetor cleaner. Smear the o ring with some pipe dope and put it back together.
Dave in DenverThere was an error rendering this rich post.
Thanks to all
Thanks for everyone's advice. I disassembled Spirovent and cleaned it. It seems to be working fine again. I will also call spirotherm and have them replace it.
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
