Removing radiator sections
tony the tech
tony the tech Member Posts: 26
I do it with the wood wedges and a flat bar where needed all the time.
-tony
  • David Hohengasser
    David Hohengasser Member Posts: 52
    After I cut the rods, what is the best way to separate the sections. It is a steam radiator with conncetions only at the bottom. Would wood splitting wedges work? Can metal be against metal, or is there a risk of cracking the cast?
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,827
    Steam Radiators
    ...with nipples only on the bottom are often connected with screwed-in nipples instead of rods. If there are rods, they are probably push nipples and can be separated with blocks of wood and a bar, maybe tapped with a small hammer. But if they are threaded, you'll find out when the block goes through the casting.
    Good luck.
  • Dave Stroman
    Dave Stroman Member Posts: 766
    I tried on of these. Worked prety good with the toe wedge.
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44900
    Dave in Denver
