Removing radiator sections
tony the tech
I do it with the wood wedges and a flat bar where needed all the time.
-tony
-tony
After I cut the rods, what is the best way to separate the sections. It is a steam radiator with conncetions only at the bottom. Would wood splitting wedges work? Can metal be against metal, or is there a risk of cracking the cast?0 -
Steam Radiators
...with nipples only on the bottom are often connected with screwed-in nipples instead of rods. If there are rods, they are probably push nipples and can be separated with blocks of wood and a bar, maybe tapped with a small hammer. But if they are threaded, you'll find out when the block goes through the casting.
Good luck.0 -
I tried on of these. Worked prety good with the toe wedge.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44900
Dave in DenverThere was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
