PRO PRESS FOR STEAM
Boiler Guy
Member Posts: 585
Do you have more info on the FKM products. Not thinking for steam but for returns. I have tried PP on returns but found leaks where seals get flashed with vapor.
propress
Just sat thru a demstration for the Ridgid Propress. Salesman told it can be used for steam lines. Fitting and joint has a higher strength than silver solder sweat joints. Maybe I'm old school but I didn't even think copper was recommended for steam. I'm only 37 but I was tought using black pipe and thats all I have ever done. Any opinions. I have also used black pipe and swing joints on all oil tank installs but this guy was talking about using copper and propress fittings on oil tanks also. I thought you had to have swing joints. It would make installs alot quicker.0 -
propress and steam
do they make propress in 2in? what happens when it starts to sag? cant you it in MA. on oil tanks for fill or vent piping0 -
propress and steam
They make Propress all the way to 4". Propress "G" with yellow dots on fittings is being advertised (Plumbing & Mechanical) in the process of being aproved for natural & LP gas and fuel oil. As for swing joints??.............Better ask the inspector.....I would say no.
As for Steam... I doubt it. Go on the Viega web site. They have a list of approved and non approved uses.
Ed0 -
Some salesmen ..................................................
will sell you anything.....................................Mad Dog
Mad Dog,
With all due respect maybe you should change that to "Some salesmen will TELL you anything" if they think thats what you want to here0 -
You can use it on steam
up to 15 psi, but you have to use their FKM, specialty seals, which are field installed. I got this from Viega's Dann Holmes in Detroit just the other day. He was at my seminar.Retired and loving it.0 -
propress and steam
i will stick with cast iron and black iron on steam if i want to get creative i will try pvc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"1 -
No,
that's it. Just that you need that seal with steam.Retired and loving it.0 -
Propress and Steam
ProPress fittings on steam applications is just a fade.
For proper steam piping, up to 600 psi use schedule 40 PVC, just make sure you use fresh glue and primer. PVC and steam "guaranteed forever".
Just forget the STEAMFITTING TRADE, you know all the steel pipe, threading, and welding; it's dirty and heavy, and you might even catch a spark. The ProPress and PVC is cheaper, faster, and anybody can install it. That's what we're all about anyway right?1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
