Forensic Steam Problem
MD
The reset is visible right on top0 -
I agree FD
But I think the P404's should be replaced with vaporstats. I don't know about you, but I have never been really successful setting the 404 series Ptrols at very low presures with any accuracy MHO0 -
That pipe
you say "not sure where it comes from," looks like it is going into the jacket cut out for the gas supply line.0 -
Yes!!!
> gas supply line.
Yes!!!
that mysterious line is a gas line, not a return.
The shut-off is just above the boiler.0 -
The Hi-limit
is a safety control, as opposed to a operating control. It can be set to the operators discretion, but it will need to be set at a higher setpoint than the operating control cut-out or nusiance shutdowns may occur requiring manual reset. It is just fine at 10psig and probably best to keep it there. As a general rule 5 psig over cut-out is satisfactory to avoid non-attended boiler shutdown.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
