Crown boilers vs. Weil Mcclain or Burnham
Darren_5
Member Posts: 11
How would you rate the Crown Boiler? I have a 3 family rental and need 3 boilers 60,000btu each. Is crown acceptable in the industry or is it considered low budget? How bout construction wise?
Some of the folks here love the oil units
The Tobago's your average pin type cast iron boiler. The Freeport is a nice high efficent 3 pass scotch marine design with german castings. Their gas units are probably made by Dunkirk, which are also OK cast iron boiler. There are not the higher efficency models.0 -
They are all good
brands.
If the job calls for a sealed combustion I feel the Crown CSC Cabo has a leg up on competitors. I'm a big fan of sealed combustion!
Wet leg casting design, and a nice, Taco built, control board with DHW priority built onto the board. The controls are all under the hood for looks and protection, and safer shipping, nice touch
I also like the color comb on the jacketing
hot rod
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
