Water Testing
S Davis
S Davis Member Posts: 491
I need a good test kit for testing boiler water ph, hardness etc. anyone have any suggestions?
Thanks
S Davis
  • Robert O'Connor_6
    Robert O'Connor_6 Member Posts: 299
    Check out these guys
    I met them at Wetstock, They hang out here . I haven't used them yet . But I bet they will take care of you!
    http://www.rhomarwater.com/
    Regards,
    Robert
  • hr
    hr Member Posts: 6,106
    The basic stuff
    I like the Hach brand digital ph tester. Check calibration ocassionally. www.hach.com
    The hardness, iron, ph test kit is another must have. This one is from the Graingers catalog. It may be a Hach brand also.
    Then of course the glycol tester that handles propylene and ethylene www.misco.com
    If I need anymore info, or problematic fluids, I send them to a lab. Or in the case of glycols, Dow.
    hot rod
  • hr
    Basic testing
    I like the Hach digital ph tester www.hach.com Check calibration ocassionally.
    This softness, iron, ph kit is from Graingers. It may be a Hach brand also.
    The glycol tester is from www.misco.com.
    For real head scratchers, I send a sample to a lab, or in the case of glycol Dow.
    hot rod
  • George_10
    George_10 Member Posts: 580
    S Davis
    We have the kits and we also do testing for our cleaner/treatment clients.
    We also carry the sweet pH testers. They are slick and can be kept calibrated by using their stable 7.0 tester fluid.
    It sure beats paper testing. My number is 800-543-5975.
