Water Testing
S Davis
Member Posts: 491
I need a good test kit for testing boiler water ph, hardness etc. anyone have any suggestions?
Thanks
S Davis
Thanks
S Davis
Check out these guys
I met them at Wetstock, They hang out here . I haven't used them yet . But I bet they will take care of you!
http://www.rhomarwater.com/
Regards,
Robert0 -
The basic stuff
I like the Hach brand digital ph tester. Check calibration ocassionally. www.hach.com
The hardness, iron, ph test kit is another must have. This one is from the Graingers catalog. It may be a Hach brand also.
Then of course the glycol tester that handles propylene and ethylene www.misco.com
If I need anymore info, or problematic fluids, I send them to a lab. Or in the case of glycols, Dow.
hot rod
Basic testing
I like the Hach digital ph tester www.hach.com Check calibration ocassionally.
This softness, iron, ph kit is from Graingers. It may be a Hach brand also.
The glycol tester is from www.misco.com.
For real head scratchers, I send a sample to a lab, or in the case of glycol Dow.
hot rod
S Davis
We have the kits and we also do testing for our cleaner/treatment clients.
We also carry the sweet pH testers. They are slick and can be kept calibrated by using their stable 7.0 tester fluid.
It sure beats paper testing. My number is 800-543-5975.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
